Graph animation - Messages
#22 Posted: 2/16/2013 4:24:34 AM
optical illusion
The idea is taken from the site
http://www.mapleprimes.com/maplesoftblog/35171-Its-Better-With-Maple
Although the vertical distance between the curves is constant,
it seems that with increasing distance from the axis of Y, they are getting closer.
Animation helps to overcome this optical illusion
Illusion.sm (5.04 KiB) downloaded 1108 time(s).
Davide Carpi 2/16/2013 7:42:00 AM
#24 Posted: 3/2/2013 1:16:50 AM
Bullseye Illusion
The idea is taken from the site:
[url]: http://demonstrations.wolfram.com/BullseyeIllusion/[/url]
Although the white region has the same area as the blue ring, it appears to be larger
Bullseye.smz (2.92 KiB) downloaded 1088 time(s).
#25 Posted: 7/28/2013 2:41:20 PM
Animation examples from the book “Introduction to Statics and Dynamics
by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009”
http://archive.org/download/ost-engineering-ruinapratap8-21-10/RuinaPratap8-21-10.pdf
Planar motion1.smz (74.44 KiB) downloaded 1120 time(s).
#26 Posted: 9/12/2013 2:13:27 PM
Three Dissections by Leonardo da Vinci
http://demonstrations.wolfram.com/ThreeDissectionsByLeonardoDaVinci/
Leo2.smz (5.61 KiB) downloaded 1010 time(s).
#27 Posted: 9/16/2013 8:46:53 AM
Challenge for Ber7 :d
This would be a great SMath animation : Heatherwick's Rolling Bridge
See it in action on this video at 1 minute and 25 seconds :
?t=1m25s
?t=1m25s
#28 Posted: 9/16/2013 1:22:27 PM
Thank you for the wonderful example .
I'll try to implement it.
Davide Carpi 9/16/2013 1:37:00 PM
#29 Posted: 9/19/2013 12:54:23 AM
Davide Carpi 9/19/2013 12:56:00 AM, Вячеслав Мезенцев 9/19/2013 11:22:00 AM, ioan92 9/25/2013 5:13:00 PM
#30 Posted: 9/25/2013 4:42:16 PM
Nice, Rolling Bridge!
See you this:
The author
See you this:
The author
#31 Posted: 10/3/2013 3:55:36 AM
http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf
A spring-mass system in space
A spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg,
and a weak spring with stiffness k = 1N/m. The spring has zero relaxed
length.The system is in 3-D space where there is no gravity. Track the
motion of the system for the next 20 seconds. Plot the trajectory of
the two masses in space. The 3-D animation showing the trajectory of the
two masses obtained from the numerical solution . From the plot, it seems
like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory.
springMass4smz.smz (5.49 KiB) downloaded 1077 time(s).
Davide Carpi 10/3/2013 5:39:00 AM
#32 Posted: 10/3/2013 5:32:30 AM
Nice one Ber7!
archive.org had a problem with the link. The book can be found here:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Brian
Brian
#33 Posted: 10/3/2013 6:37:02 AM
Thank you very much, corrected.
Davide Carpi 10/3/2013 8:13:00 AM
#34 Posted: 4/21/2018 2:34:39 PM
Animation of NPlot and 3d Plot graphs
The program is designed for graphs that do not have a built-in
animation capabilities
3dplot mk.sm (8.5 KiB) downloaded 973 time(s).
NplotAnimation.sm (14.61 KiB) downloaded 1006 time(s).
frapuano 4/23/2018 3:02:00 AM
